Hello Guest it is November 10, 2026, 03:16:09 AM
Author Topic: Smal bug feed hold in I, J comands  (Read 11399 times)
« on: April 22, 2009, 05:53:42 AM »
When I'm running a line of code containing I and J comands it is necessary to hit feed hold twice for the action to take place. On the first hit the actual arc section in the tool path window lit up, but the feed continues. On the next hit the motion stops. If running a straight line motion stops on the first hit of the feed hold button.
Is this as it is intended to be?
I'm running version R3. 042. 020.
Anyone of you guys experiencing the same behaviour?
Re: Smal bug feed hold in I, J comands
« Reply #1 on: April 22, 2009, 06:03:39 AM »
That bug has been there on and off for a while, think its sorted in 026 if I remember correctly.
