Hello Guest it is November 17, 2026, 04:40:31 AM
Author Topic: Backwards Text  (Read 13542 times)
Backwards Text
« on: April 21, 2009, 07:34:40 PM »
Hi Everyone,
I am new to CNC and Mach 3.  With that said I am using Cut2D as the cad/cam program.  In Cut2D there is a sample of text called "rocket".  When I load the G code into Mach 3 and begin to machine it out the text comes out backwards.  You can only read it in a mirror.
Does anyone know what I am doing wrong or have any ideas as to why the text is backwards?
It displays correctly in the tool path but cuts wrong.  I double checked the ports and pins setup and the table setup but still haven't found anything out of place.
I am using Gecko G203V's as the drivers for the stepper motors and I am using a PMDX 132 for the computer interface.
Any help would be appreciated.
Thanks.
Offline docltf
  •  354 354
Re: Backwards Text
« Reply #1 on: April 21, 2009, 07:51:44 PM »
you got one of your axis set in the wrong direction.go to homing and limits drop down menu and reverse one of them.pick witch one you think will do it X or Y.
Re: Backwards Text
« Reply #2 on: April 23, 2009, 05:38:55 PM »
Thank You Docltf.
You were right.  Apparently I had the "X" axis reversed in the ports and pins setup.
Once I corrected it the text comes out the way it's supposed to.
