Hello Guest it is November 15, 2026, 09:09:54 AM
Author Topic: Need help to on "GO TO"  (Read 10531 times)
Offline Psad
  •  82 82
« on: August 05, 2006, 08:31:42 PM »
How does the "GO TO" button on the "Program Run" screen work.
I appears that it changes the coordinate system referenced to the tooling position.
Is that true.
Re: Need help to on "GO TO"
« Reply #1 on: August 05, 2006, 11:34:43 PM »
Go To Button??  Are you talking about the Go To Z Button?  Which version of Mach3 are you runing?
Sid
« Reply #2 on: August 06, 2006, 06:14:10 PM »
It tells you the Distance to Go for that block... When the DRO's read 0,0,0 the move is done...
www.newfangledsolutions.com
www.machsupport.com
