Hello Guest it is November 19, 2026, 01:18:16 PM
Author Topic: Setting different feedrates for each axis.  (Read 10314 times)
« on: April 20, 2009, 06:04:33 PM »
Hello people.
I've been bitten by the hobby CNC bug, so i have my own machine now up and running. G-code(rs274) is really nice, as it is similar to what we use at my place of work, Sieb&Meyer sintax.
I have a small problem though:  would it be possible to specify the feedrate for each axis at the begining of a program?  When drilling thin boards i would like more speed on the Z-axis. I'm thinking something like this: FX 1500 FY1500 FZ 2500. Can it be done without specifying the the higher feedrate on every line that the Z drops or retracts?
Thank you.
Re: Setting different feedrates for each axis.
« Reply #1 on: April 20, 2009, 07:57:52 PM »
Somnozaur,
Are you using MACH?
« Reply #2 on: April 20, 2009, 07:58:42 PM »
You could lower the speeds of the X and Y in motor tuning to the max you want them to go.
« Reply #3 on: April 21, 2009, 12:53:43 AM »
Yes, I'm using mach.
Thanks for the motor tuning ideea, i think it might work.
