Hello Guest it is November 19, 2026, 05:56:46 AM
Author Topic: Is there and easier way to comment.  (Read 18214 times)
« on: August 05, 2006, 10:53:11 AM »
I'm looking for an easier way to add comments/notes to my g-code other than enclosing the line in Parentathes.  I'm not a great typist and would like to know if there is a single stroke method such as a semi-colon, apostrophe, slash, dash,etc.
Eugene
Re: Is there and easier way to comment.
« Reply #1 on: August 05, 2006, 03:18:17 PM »
I found some answers in the Mach3 manual, of course the last place I looked after 3 hours of searching the forums.
I can't get Mach3 to accept the // for a comment.  Any ideas?
Also, how do I turn on block delete?
thanks again.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #2 on: August 05, 2006, 08:40:51 PM »
Hi, Eigene
Try (your comment) on it's one line or end of Gcode line, g01 x1y2(comment)
Chip
« Reply #3 on: August 06, 2006, 06:28:03 PM »
I think you can also do this
G00 X.00 Y.00 ;This will move to X0 Y0
www.newfangledsolutions.com
www.machsupport.com
« Reply #4 on: August 06, 2006, 10:35:20 PM »
Thanks guys. The semicolon definately works as does the % symbol and of course parenthesis.  The slash / works with block delete enabled only.  I think I will stick with the semicolon as it's the easiest.
