Hello Guest it is November 07, 2026, 02:06:34 AM
Author Topic: Where is the current screens saved?  (Read 15515 times)
« on: April 12, 2009, 06:42:16 PM »
I downloaded the Mach3 screen designer. I would like to play with the standard screens, see what I can change. I suppose it is possible to load the standard screens into the screen designer, but I cant find a file for the standard screens. Does such file exists and if so where can I find it?
I have found all the bitmaps for the backgrounds and buttons though.
Re: Where is the current screens saved?
« Reply #1 on: April 12, 2009, 06:50:40 PM »
Its in the C:\Mach3 directory, its called 1024.set
« Reply #2 on: April 12, 2009, 06:59:20 PM »
Ahh, thanks Hood!  :)
« Reply #3 on: April 13, 2009, 01:33:16 AM »
My desktop didn't like that program at all. It opens fine, but when I load the 1024 file it immediately runs into trouble. The PC is running at 100% load for a considerable time, say 10 to 15 sec before anything happens, then all the screens load simultaneously, a terrible mess. If I hit escape then only one screen is visible, but it is still very unstable, doesn't look like the program read the file completely correct and it crashed two times in 20 min of trying to get it to work. I have an old xp version.
Is it something with my PC? Should it work on any PC?. I tried to run it in compatibility modes for windows 2000. It didn't help.
« Last Edit: April 13, 2009, 01:36:31 AM by SteinarN »
« Reply #4 on: April 13, 2009, 05:02:47 AM »
Screen 4 doesn't work in Vista.
Try this one.
http://www.machsupport.com/forum/index.php/topic,11122.0.html
« Reply #5 on: April 13, 2009, 06:12:29 AM »
« Reply #6 on: April 13, 2009, 07:17:06 AM »
I had originaly downloaded the Mach3 screen designer. That didn't work. I downloaded the Screen4. Works like a dream under xp  :)
