Hello Guest it is October 21, 2026, 03:14:18 AM
Author Topic: New install of Mach3 and now probe won't work anymore  (Read 10652 times)
« on: April 10, 2009, 03:24:03 AM »
Hi
This week I had to re-install Mach3 because to much trouble after installing a plugin for a Shuttle Express.
My probing Macro as well as my tool setter macro were working very well.
Probe work great in X and Y direction
For the probing in the Z direction, detect OK, retract but instead of retracting to the value of the GetVar(2002), which is suppose to be negative, the Z axis want to continue pass the Z home switch because when I
check what is the Var 2002, I get a positive value which is not suppose to be like it, it should be negative since the Z axis have been referenced.
Before re-installing Mach3, I made a copy of all my macro so they are all identical.
Don't know what could be the problem and why I get the positive Variable.
Thanks, Jeff
