Hello Guest it is November 22, 2026, 11:23:38 PM
Author Topic: auto set z  (Read 11616 times)
Offline Ed
  •  15 15
auto set z
« on: April 09, 2009, 09:14:37 PM »
I have a micro switch setup I would like to hook up to let my tool on my z move over to and touch to automatically set my z. How would i go about hooking this up.
Thanks Ed
Re: auto set z
« Reply #1 on: April 11, 2009, 02:10:01 AM »
First you need to have the hardwire done (connect your micro).
After this you need to set up in the config ports and pins the pin number that you connected the micro to a signal.
If you need to set Z, then the most direct form for you is the signal "Z Home" in the input signals window.
Now you can "home" and Z will automatically reset.
In the manual this is more detailed.
Re: auto set z
« Reply #2 on: April 11, 2009, 04:26:07 AM »
Do a search for tool height macro and you should find info or contact Brett (Chaoticone) as I think he does similar.
