Hello Guest it is September 25, 2026, 07:52:19 AM
Author Topic: Servo Dynamics  (Read 14176 times)
Aaronp
Servo Dynamics
« on: August 02, 2006, 09:35:48 PM »
Has anybody interfaced servo dynamics amps to mach 3 or 4?
The amps that I can get free of charge require a 10+ to 10- volt DC input to control rotation.
I was wondering what hardware and such people were using?
aaron
Re: Servo Dynamics
« Reply #1 on: August 03, 2006, 04:49:41 PM »
If you are into electronics What you will need is an 8 bit up/down counter connected to the step and direction outputs of mach3
and the same for your encoder then both 8bit outputs from the counters are fed to an 8 bit adder. This will give you the error signal in digital form. You will then need to convert the 8 bit error output from the adder to analouge with an A to D converter with an output offset to give the +10-10 command signal.
It might be worth having a chat with the guys at CNC4PC as they do some converter boards and I would have thought that a frontend for these old drivers would be ideal for a retrofit.
Regards
CJ
Jaime
Re: Servo Dynamics
« Reply #2 on: January 30, 2007, 02:15:01 PM »
follow this link, this is the pixie 100,
  In: pulse/dir
out: +/-10 V
http://www.skyko.com/products/
