Hello Guest it is November 22, 2026, 07:07:35 AM
Author Topic: Offset Question  (Read 11433 times)
Offset Question
« on: April 05, 2009, 06:16:01 PM »
Hello,
I am a nwe CNC user and using MAch3, Lazycam to create G codes.
I have a problem arranging the offsets.
Let's say I need a rectangle cut of 10mm X 20 mm and I use a 1 mm fraise. How can I arrange the tool to cut outside the line so that I can get a 10mmX20mm clean rectangle.
I tried to use LazyCam's offset options but it did not help.
Is there a way to make it in Mach3?
Thanks in advance.
Harun
Re: Offset Question
« Reply #1 on: April 05, 2009, 07:10:06 PM »
Offset the lines in your CAD program before importing to LazyCAM.
