Hello Guest it is November 22, 2026, 08:26:04 AM
Author Topic: ± issue with v3.042.025?  (Read 16602 times)
Offline Tarak
  •  229 229
« on: April 03, 2009, 05:36:54 PM »
Hi Guys, I just upgraded to v3.042.025 from an older version (quite a few revisions ago) and I've noticed that my dro's will not accept a negative value unless the format string for the dro is set to %+.4f, previously I had %.4f so as it wouldn't show the positive symbol but it would still show the negative symbol.
Has the formatting for the dro's changed?
Darc
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: ± issue with v3.042.025?
« Reply #1 on: April 05, 2009, 04:13:29 AM »
Yes, its to do with the incremental input,  if you highlight a DRO and press the + key and enter .1 it will add .1 to the value, if you press the - key and enter .1 it will minus it off the value, for it to work the format string must have the + sign in it.
Graham
Offline Tarak
  •  229 229
« Reply #2 on: April 05, 2009, 11:22:40 PM »
Thanks Graham, That actually explains alot. I like the idea of that.
« Reply #3 on: April 07, 2009, 06:29:37 PM »
Just for your info you can also multiply and divide direct into a DRO as well, division being very handy in my opinion :)
Offline Greolt
  •  956 956
« Reply #4 on: April 07, 2009, 08:34:07 PM »
I never knew that.  Learn something everyday.
However I must be doing something silly.  Not unusual.  ;D
I can not get it to minus any value.  If the value is 10 and I minus 2 it should then read 8 right?   It reads -2
+, * and  /, all work as expected but not -
Tried all sorts of combinations of entry and can't get it right.  Can someone set me straight.
Greg
« Reply #5 on: April 08, 2009, 03:08:06 AM »
Never actually tried a -subtraction, maybe you need to add a negative number? Will test it out in a bit once I get Mach installed on this computer.
« Reply #6 on: April 08, 2009, 03:19:58 AM »
Yes, seems to work if you add a negative number, seems a bit of a strange way to have to do it but I suppose it is because you have to be able to also enter a negative value direct into the DRO like before.
