Hello Guest it is November 01, 2026, 01:44:24 PM
Author Topic: Mach3 4.0 Rev Update  (Read 136392 times)
Offline lemo
  •  135 135
Re: Mach3 4.0 Rev Update
« Reply #20 on: June 25, 2009, 04:18:27 PM »
He probably needs more of this stuff:
Cut five times and still to short...
Offline drew
  •  79 79
« Reply #21 on: June 25, 2009, 10:55:46 PM »
In turn I could find no way or dro that stored the offset number that was applied to the turret durring the tool change command.
In milling this is not much of an issue, but in turning sometimes you dont use the same offset number as tool number.
asper : tool 1 with a .031 nose radius say T0101
     or   tool 1 with a .015 nose radius say T0111
If you can please add this if I am not overlooking it.
Thanks Drew
If I had something important to say it would be here.
« Reply #22 on: June 26, 2009, 01:03:35 AM »
Thanks Drew
It is also something I have wanted for a long time and Brian will be adding it when he  gets working on Turn.
« Reply #23 on: June 26, 2009, 08:41:43 AM »
Rev 4 has been going well.. I have started to send it off to the alpha testers :) I am working on the Run From Here code, after that is done I need to do reverse run. Then I think it will be just about ready for bata testing :)
I think Plasma will be after mill as it is very few changes and the same display.. Then Yes you got it Hood TURN! Turn is going to take me a long time as I would like to redo most of the turn code :)
Well back to work for me :)
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #24 on: June 26, 2009, 09:11:19 AM »
Thanks for the update Brian.  Sounds good.  My background is in Systems Analysis (Graphics applications in C and Assembly ... and accounting applications in COBOL), and although I have not written much software in the last 10 or 15 years, I have a feel for what is involved in getting a program of this magnitude designed and running - let alone "bug free".
By the way, although I am not entirely sure what you would require of me, I would be willing to be a tester of the new release.
Joe
« Reply #25 on: June 26, 2009, 09:20:14 AM »
Pissed off but it was expected.
« Reply #26 on: June 26, 2009, 09:37:03 AM »
I am thinking at this time that I will post a link here to the Rev4 software as soon as it is ready for Bata testing :)  I don't think general public would be happy if I put the link on the web page and have them on the bleeding edge LOL..
Brian
www.machsupport.com
« Reply #27 on: June 26, 2009, 09:38:39 AM »
Hood... We will make your lathe act like it is bigger then it is when we are done.. I am fast getting to the point that I can start working on the turn code :) Only a small buit of Plasma code to do !
Brian
www.machsupport.com
vmax549
« Reply #28 on: June 26, 2009, 10:04:48 AM »
BRIAN you had better get the plasma done RIGHT(:-) I am just finishing up on a brand new PLASMA table.  HECK we gave you an extra $16, mach had better be the cats meow for that much exta mula.
Still looking for a good donor LATHE to retro (;-) TP
LOL, (;-0 TP
Offline lemo
  •  135 135
« Reply #29 on: June 26, 2009, 11:26:57 AM »
Till then I made some Mach 4 Fan Art to look at in the meantime 8). Hope you like it...
Or as alternative:
http://www.onesmall.com./stuff/mach4_plan.jpg
