Hello Guest it is October 20, 2026, 09:20:16 PM
Author Topic: init.m1s  (Read 15704 times)
Offline Bill_O
  •  615 615
init.m1s
« on: March 30, 2009, 07:59:44 AM »
If I make a macro called "init.m1s", to ensure leds are turned off, does it run only when mach starts?
Bill
  •  9,374 9,374
Re: init.m1s
« Reply #1 on: March 30, 2009, 08:07:55 AM »
Hi Bill,
Surely if you add a screen button and assign the script there you can run it at any time by clicking on the button.
Tweakie
Re: init.m1s
« Reply #2 on: March 30, 2009, 08:35:12 AM »
Bill,
   Yes, you can put the name of your macro in the "init" box, under general config you would name it for instance:
m999 or what ever. Then in that macro put all your SetUserLED(*********x,0) list in it.
It will ONLY run at Start up of Mach3.
scott
Offline Bill_O
  •  615 615
Re: init.m1s
« Reply #3 on: March 30, 2009, 09:48:18 AM »
Scott,
Thanks again. Just what I needed.
Bill
Offline Bill_O
  •  615 615
Re: init.m1s
« Reply #4 on: March 30, 2009, 09:50:47 AM »
Tweakie,
If it was me running the machine no problem. I have to make this as easy as possible for the operator. The less they have to do the less likely something will get forgotten or not done.
Bill
  •  9,374 9,374
Re: init.m1s
« Reply #5 on: March 30, 2009, 10:21:13 AM »
Thanks Bill - I understand.
