Hello
Guest
it is
October 15, 2026, 10:29:55 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Need help
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Need help (Read 11838 times)
keeman00
2
Need help
on:
March 30, 2009, 07:33:24 AM »
HI I am new in cnc machines and i have problem to config my cutting speed when i load some file for example 1 line which is long 1 meter mach3 cut this for 1 min.My question is how to cut the same line for 10 sec .What I have to change.
Graham Waterworth
2,785
Yorkshire Dales, England
Re: Need help
Reply #1 on:
March 30, 2009, 12:19:25 PM »
The F command controls the feed rate of the axis, if you are working in metres then the feed you have is F1000. to move 1 metre per minute, to make it move 1 metre in 10 seconds then you have to move 6 times faster so F6000. will do this.
Graham
keeman00
2
Re: Need help
Reply #2 on:
March 31, 2009, 09:53:14 AM »
Thank you I tried and works Actually before to load file in mach3 i can adjust my feed rate in lazycam I think .
But thank you for the fast answer.
I need that because I'm building plasma table (X=1m y=2m) I will cut about 1 mm steel thats I need fast cutting speed.If you can somebody can give me some tips I will be happy to learn.
Last Edit: March 31, 2009, 10:01:47 AM by keeman00
Print
Pages:
1
Go Up
« previous
next »
