Hello Guest it is October 04, 2026, 12:06:52 AM
Author Topic: Input Box Function  (Read 8667 times)
Offline Greolt
  •  956 956
Input Box Function
« on: March 28, 2009, 11:58:33 PM »
I found this on the Cypress Enable Language document.
Sub Main ()
  Title$ = "Box to ask for a number"
  Prompt$ = "Enter the number"
  Default$ = ""
  X% = 200
  Y% = 200
  N$ = InputBox$(Prompt$, Title$, Default$, X%, Y%)
End Sub
When this Input Box is run where is the answer?
How do I retrieve it?   Where is it stored?  In a parameter?  I am looking for an integer.
I hope that makes sense.  I don't even know enough to ask the right question.   ;)
Greg
Re: Input Box Function
« Reply #1 on: March 29, 2009, 09:31:11 AM »
N$  is the string that the user types in.
The type that N$ is a string, if you want it to be a number you will need to use a string to int or decimal or float function from the book.
scott
Offline Greolt
  •  956 956
« Reply #2 on: March 30, 2009, 06:07:07 PM »
Thanks Scott
It was fairly obvious once I saw it.  Usually is isn't it.  ;D
Dim P583 As Integer
Default$ = ""
X% = 200
Y% = 200
P583 = InputBox$(Prompt$, Title$, Default$, X%, Y%)
Greg
