Hello Guest it is November 07, 2026, 02:06:33 AM
Author Topic: MACRO , Tool Table Report  (Read 50703 times)
vmax549
« on: March 27, 2009, 07:38:57 PM »
Here is a macro to scan the tool table file and print it out to the local printer. It also write a file copy to the Mach directory called ToolTableReport that can be read from notebook.
You can run it from a button or the MDI
Code Example:
'Macro ToolTable Report
'newer version will poll up To 225 tools And skip Any tool With a description of "empty"
' overwrite file = C:\Documents and Settings\All Users\Desktop\ToolInfo.txt
textFilePath = "C:\mach3\ToolInfo.txt"
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objTextFile = objFSO.CreateTextFile(textFilePath)
Do Until num=225
num=num+1
N = GetToolDesc(num)
D = GetToolParam(num,1)
L = GetToolParam(num,2)
WD= Gettoolparam(num,3)
WL= Gettoolparam(num,4)
If N <>"Empty" Then
objTextFile.WriteLine("*Tool"& num &"  * "& N &" *Diameter: "& D &" *Length: "& L &" *Wear Diam"&WD &" *WearLength"&WL & Chr(13) & Chr(10))
Else
End If
Loop
objTextFile.Close
Dim sCOMMAND As String
 sCOMMAND="print c:\mach3\toolinfo.txt"
 Shell("c:\winnt2\system32\cmd.exe /c" & sCOMMAND)
End
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: MACRO , Tool Table Report
« Reply #1 on: July 13, 2009, 10:56:32 PM »
Hi Terry
Thanks for sharing all these M1S files, It gives us allot of good examples to work with and put to use.
I see on this one you've used the name ToolTableReport,m1s, Is this allowed in the Mach3 Rev. 4 your testing ?.
Hopping it is and maybe some day some of us will get a Look at it Hear.
Thanks, Chip
« Reply #2 on: August 04, 2009, 12:20:17 PM »
Code Example:
Do Until num=225
num=num+1
If N <>"Empty" Then
Else
End If
Loop
objTextFile.Close
End
Wow. Other than adding tool wear diam,  wear length, and lpt printing, it's a verbatim lift of a post I made last year.   ::)
http://www.machsupport.com/forum/index.php/topic,4290.20.html
"If you tell a lie big enough and keep repeating it, people will eventually come to believe it." - Joseph Goebels
vmax549
« Reply #3 on: August 04, 2009, 08:29:09 PM »
KEith and your point is?????  Do you see where I claimed exclusive ownership of the code???  DO you see where it was added to and passed along for others to use??
I suggest IF you do NOT want your code to be reused that you DO NOT POST IT ON A PUBLIC FORUM.
« Reply #4 on: September 04, 2014, 09:21:39 AM »
i updated the macro for win7. it doesn't printer to printer but brings up Write.exe
hope this helps someone.
Do Until num=225
num=num+1
If N <>"Empty" Then
Else
End If
Loop
objTextFile.Close
 Shell("c:\Windows\System32\write.exe /c" & sCOMMAND)
End
Code Example:
Do Until num=225
num=num+1
If N <>"Empty" Then
Else
End If
Loop
objTextFile.Close
End
« Last Edit: September 04, 2014, 09:24:56 AM by Kenneth »
Kenneth
