Hello Guest it is November 26, 2026, 02:02:00 PM
Author Topic: Cutter radius comp problem  (Read 39967 times)
« on: December 29, 2005, 03:54:22 PM »
Hello,
I got a problem when I use radius compensation, when I load the file Mach complains about:
'Cannot use g28 or g30 with cutter radius comp on line #56'
If I remove G41 and G49 then it works but I can't understand why it wouldn't work with the rad comp.
Please see following code:
// Roger
O1
G90 G80 G28 G40 G17
(NOLLPUNKT I INRE VANSTRA HORN UPPE PA BITEN.)
(TOOL 1)
(PINNFRAS TUSA 6MM)
(OPERATION 7)
N1 T1 M6
S9800 M3
G0 X0 Y0
G43 Z3. H1
M8
G0 Z2.5
X130.7468 Y-36.3036 Z3.
Z2.5
G1 Z-2. F100.0
G41 X131.4302 Y-42.2645 D21
G2 X44.4616 Y-32.0091 I-21.7351 J189.5675 F200.0
X44.4253 Y-31.9957 I1.0252 J2.818
X42.4812 Y-28.545 I0.9899 J2.8307
G1 X38.0785 Y-27.6145
G2 X38.3755 Y-26.5817 I7.3367 J-1.5505
X33.2157 Y-25.4324 I46.3412 J220.2095
X33.1782 Y-25.527 I-20.5635 J8.0964
G3 X38.0785 Y-27.6145 I76.5169 J172.83
G1 X42.4812 Y-28.545
G2 X45.9361 Y-26.2119 I2.934 J-0.62
G3 X131.5177 Y-24.6452 I38.7806 J219.8397
G2 X133.4214 Y-24.8631 I0.6287 J-2.9321
G1 X135.2884 Y-29.1499
G3 X136.9862 Y-35.934 I27.1152 J3.1817
G1 X138.2203 Y-35.7854
G2 X136.4469 Y-28.6997 I24.1833 J9.8172
G1 X134.9051 Y-23.6031
G2 X135.2476 Y-21.0378 I27.4985 J-2.3651
X30.0462 Y-20.021 I-50.5309 J214.6656
X26.9364 Y-27.6181 I-17.394 J2.685
G3 X136.3859 Y-44.3582 I82.7587 J174.9211
G1 X141.6076 Y-43.7691
X139.4445 Y-41.2862
G2 X137.954 Y-38.7736 I22.9591 J15.318
G1 X141.9404 Y-36.6857
G2 X142.3008 Y-14.589 I20.4632 J10.7175
X25.3426 Y-14.0856 I-57.5841 J208.2168
X19.074 Y-28.754 I-12.6904 J-3.2504
G3 X151.3828 Y-46.2697 I90.6211 J176.057
G2 X141.9404 Y-36.6857 I11.0208 J20.3015
G1 X137.954 Y-38.7736
G2 X135.3588 Y-41.7727 I-2.9986 J-0.0276
X131.4302 Y-42.2645 I-25.6637 J189.0757
G0 Z3.
X0 Y0
(TOOL 2)
(PINNFRAS 8MM TUSA)
(OPERATION 8)
M9
G90 G80 G28 G17
G49 G0 Z0 S300 M5
N2 T2 M6
S8000 M3
G0 X11.6522 Y2.664
G43 Z3. H2
M8
G0 Z2.5
G1 Z-2. F100.0
G41 Y-2.336 D22
G3 X12.6522 Y-3.336 I1. J0
G2 I0 J-14. F200.0
X13.6514 Y-3.3717 I0 J-14.
G3 X14.7202 Y-2.4456 I0.0713 J0.9975
G1 G40 X15.077 Y2.5417
G0 Z3.
X0 Y0
M9
G90 G80 G28 G17
G49 G0 Z0 S300
M5
G0 X0 Y0
M30
Re: Cutter radius comp problem
« Reply #1 on: December 29, 2005, 07:29:28 PM »
Hello,
// Roger
O1
G90 G80 G28 G40 G17
(TOOL 1)
(PINNFRAS TUSA 6MM)
(OPERATION 7)
N1 T1 M6
S9800 M3
G0 X0 Y0
G43 Z3. H1
M8
G0 Z2.5
Z2.5
G1 Z-2. F100.0
X139.4445 Y-41.2862
G40 X131.4302 Y-42.2645 I-25.6637 J189.0757  (added a G40 to this line)
G0 Z3.
X0 Y0
(TOOL 2)
(PINNFRAS 8MM TUSA)
(OPERATION 8)
M9
G90 G80 G28 G17
G49 G0 Z0 S300 M5
N2 T2 M6
S8000 M3
G0 X11.6522 Y2.664
G43 Z3. H2
M8
G0 Z2.5
G1 Z-2. F100.0
G41 Y-2.336 D22
G2 I0 J-14. F200.0
G0 Z3.
X0 Y0
M9
G90 G80 G28 G17
G49 G0 Z0 S300
M5
G0 X0 Y0
M30
PLease look at the line I added the G40 to and see if that hepls it
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: December 30, 2005, 05:50:34 AM »
Thanks again Brian,
I will try that tonight. I'm not sure why my post processor didn't put in G40 at that line
because it did at the second operation.
Maybe because the radius compensation continued on the second operation. ???
I will check if I can change the post processor to always put in a G40.
Roger
« Reply #3 on: January 03, 2006, 04:28:21 AM »
Hi, now I got the G41 and G40 to work as it should, but when I tried to use the compensation by changing
the tool wear in the tool table nothing happens.
I was trying the following code posted from my cam program:
(TOOL 3)
(MILL 12MM)
(OPERATION 3)
X159.9999 Y-4.
G1 Z-4. F100.0
G41 Y-9. D23
G3 X164.9999 Y-14. I5. J0
G2 I0 J-21. F200.0
I0 J-21.
X165.9995 Y-14.0238 I0 J-21.
G3 X171.2318 Y-9.2675 I0.238 J4.9944
G1 G40 X171.4698 Y-4.2731
G0 Z3.
The postprocessor added D23 for tool 3 is that wrong? must the D value be the same as
the tool number?
/Roger
« Reply #4 on: January 03, 2006, 05:22:02 AM »
Well I run Fanuc by day so I can tell you why the heck this would ever be the right thing to do:) In a fanuc (but not all) the tool comps pull from memory locations NOT a table. So if you have a 20 tool changer, 1-20 are all tool length comp and 21-40 are dia. This is not a set rule it is just how most people do it.
You don't need know this to run Mach3 :) in Mach3 it is in a table so you only need to do H3 and D3. Please change the post and I think you will be good to go.
www.machsupport.com
« Reply #5 on: January 03, 2006, 05:16:07 PM »
Yes your right Brian I was using Fanuc 6 post and now I removed the D value completly.
According to the manual Mach uses the cutter comp slected tool if theres no D value, right?
And does Mach use the tool diameter in the tool table in any way, for ex. in cutter comp?
Roger
« Reply #6 on: January 03, 2006, 07:43:31 PM »
You can use  the auto d = tool that you have in thing... That should work!
"And does Mach use the tool diameter in the tool table in any way, for ex. in cutter comp?...."
I think you are asking if this is what it is going to get for a val? You are correct
PS the other thing you can do is :
G41 P.125 for a .25 Mill this will make it so you don't need to set anything in the tool table :)
Hope that helps
www.machsupport.com
« Reply #7 on: January 04, 2006, 05:56:31 AM »
Brian you wrote "You can use  the auto d = tool that you have in thing... "
is that in mach or in the postprocessor?
About the tool table I understand the tool lenght and wear but does it matter
what I type in tool diameter column?
Roger
« Reply #8 on: January 04, 2006, 06:10:56 AM »
Brian you wrote "You can use  the auto d = tool that you have in mach3... "
Roger
Sorry about the the mouse on the computer I was on jumps around and I edn up with words in strange places at times....
The auto D Val is in Mach3
As for the tool table you only need to have the Dia of the tool IF you are going to call it with a G41 or G42.
Hope that helps
Brian
www.machsupport.com
« Reply #9 on: January 04, 2006, 12:03:11 PM »
Sorry Brian, I can't find the "Auto d val" in Mach.
Can you tell me where to find it please?
Roger
