Hello Guest it is October 20, 2026, 03:02:14 PM
Author Topic: Spindle speed syntax error  (Read 20142 times)
Offline Greolt
  •  956 956
« on: March 27, 2009, 03:51:52 AM »
For a little while I have been getting strange behaviour of my spindle speed control.
Thought it must be a glitch in my electronics.
The symptom I have had is, the gcode sets the rpm.  The DRO updates as it should..
But the actual RPM is whatever was last used.  Until I nudge the override, then it goes to the correct rpm.
However I have discovered there is some problem with the spindlespeed.m1s
Here is the line.  As far as I know this is Mach standard issue,
rpm = GetRPM() SetSpinSpeed( rpm )
The VB editor does not like it.  Calls a syntax error on "SetSpinSpeed"
Version R3.042.022
Greg
Re: Spindle speed syntax error
« Reply #1 on: March 27, 2009, 03:58:26 AM »
Are they on the same line in the macro? Think they should be on different lines, ie
rpm = GetRPM()
SetSpinSpeed( rpm )
Offline Greolt
  •  956 956
« Reply #2 on: March 27, 2009, 04:37:10 AM »
Yes you are spot on Hood.  That fixed it.
Funny thing is I have Mach loaded on three computers and every one of them in every profile had it on one line.
How did that happen?  Must have ghosts in the house or something.
I certainly did not do it.
Thanks,  Greg
« Reply #3 on: March 27, 2009, 04:42:49 AM »
Weird, maybe I better look at mine LOL
« Reply #4 on: March 27, 2009, 04:47:10 AM »
Just looked and mine are all OK, maybe you do sleep typing instead of walking ;D
Offline smurph
  •  1,575 1,575
« Reply #5 on: March 27, 2009, 09:51:07 PM »
In BASIC, you use a colon to separate multiple commands on one line.  You might look for the magical colon on your other three machines.  Or try it.  I have no idea if it even pertains to the VB in Mach.
Steve
« Reply #6 on: March 27, 2009, 10:06:28 PM »
Just checked mine out of curiosity.
RC
Offline Greolt
  •  956 956
« Reply #7 on: March 27, 2009, 10:25:32 PM »
Hah!!!!  I am not going mad after all.  ;D
What would do that?
Greg
« Reply #8 on: March 27, 2009, 11:27:37 PM »
I haven't a clue Greg.
This is on my office PC and only used for sim.
RC
