Hello Guest it is October 22, 2026, 09:58:20 PM
Author Topic: Lathe Servo Spindle settings question  (Read 29551 times)
Re: Lathe Servo Spindle settings question
« Reply #10 on: March 27, 2009, 03:39:04 PM »
Same tab you click on tho get to ports and pins and to motor tuning. Close to the bottom of the list.
Donny
« Reply #11 on: March 27, 2009, 04:15:58 PM »
I can't seem to get over 650 rpm. Not 675. Would my calculations being wrong on the steps per be the difference?
Calculations there wont affect the max RPM, it is purely kernel speed that will determine that. Steps per will determine the accuracy of the commanded to true though so if you had 2000 steps per rev and you actually need 4000 then your commanded speed would be double the true speed.
What it may be here is that your kernal speed is actually not a true 45KHz due to the computer you have, what does it say the pulserate is on the Diagnostics page, if it says around 43,333 you have your answer as 43,333 x 60 seconds /4000 = 650rpm
Now playing with the numbers in the Spindle Pulley screen: If I put a max speed 1000 then my actual speed is off. The only was I can get a accurate spindle speed is if I put in max speed is 650. Then when I type in a value of say 500 in the Manual screen I actually get 500 on my hand held tach. The Velocity in the Motor tuning page is set for 675.
If I put any other number in the Spindle Pulley configuration screen I get the wrong real numbers on the tach. WHY?
I do not understand this at all and that is why I queried which screen you were talking about. As far as I can remember I have not set this up and have just kept the default which I think is 5000 for pulley 1.
Now how do I go about getting a faster spindle speed? Without changing my breakout boards etc. I spent allot of time and money setting all those up in my cabinet. I need increased speed without loss of resolution in the C axis Indexing.
Only option is to go lower count  encoder or higher kernel. If my previous assumption regarding the true kernel speed is correct then increasing the kernel is unlikely to be an option. Lowwering the encoder count will hit on the resolution so the only other option I can see is to get a SmoothStepper which will allow you to get plenty of speed as it can pulse up to 4MHz.
« Last Edit: March 27, 2009, 04:19:03 PM by Hood »
« Reply #12 on: March 27, 2009, 04:26:34 PM »
Oh thought I beter mention that there are some issues with the SmoothStepper and step/dir spindles at the moment. It does now work well for me  with the exception of CSS, that just doesnt work at all or rather it does work but is unuseable as it jerks and jumps around. This I have no doubt will get fixed in time but I suspect it will not happen until the work getting done on Mach at present is complete. This is for two reasons, firstly the Mach coding that is going on will make the  ease of integrating external devices easier to write a plugin for and also it will be much more responsive. Secondly because the Mach changes will more than likely not work with old plugins then it would be a waste of time Greg doing a lot of hard work only to have to redo it all in a month or so when hopefully the Mach upgrade is out.
