Hello Guest it is September 05, 2026, 11:37:45 PM
Author Topic: My program won't run  (Read 30149 times)
Re: My program won't run
« Reply #10 on: March 26, 2009, 09:18:34 PM »
Will look tomorrow, its 2:30 am here so off for some sleep.
« Reply #11 on: March 26, 2009, 10:09:48 PM »
Here's my program. I have 3 screen shots, but I think there's enough to see if I'm doing something wrong,
« Reply #12 on: March 26, 2009, 10:17:52 PM »
And scrolled down a bit...
« Reply #13 on: March 26, 2009, 10:20:11 PM »
Last one...
« Reply #14 on: March 26, 2009, 10:21:50 PM »
avirostick,
If the program opens in MACH then just click EDIT , then save as a text file with a name of your choice.
I will assume that you have notepad as your default editor.
You can use the saved file for posting to this site. Suggest you find out what Fanuc gcode generated from
your program are not compatable with Mach. Usualy a program will provide a "post processor" specific for another program whch magicly changes the code such that it is usable for the recieving program.
Sorry but i know nothing about Fanuc specifcs.
I see you posted but will still post this.
« Reply #15 on: March 26, 2009, 10:26:05 PM »
Ok. I needed to get that info down for attaching stuff in the future. Thanks for the heads up. I'm sure it will help.
« Reply #16 on: March 27, 2009, 05:18:11 AM »
I see a few problems but I am not the best a Gcode especially when subs etc are present I will see if Graham will have a look.
« Reply #17 on: March 27, 2009, 07:42:38 AM »
I got it straightened out now. I was not starting the program in the correct place. Actually, I had too much going on in the beginning of my program and it couldn't read it correctly. Thanks a lot Hood for your help, and Rich too. I'll know how to properly attach code to the forum in the future.
