Hello Guest it is October 20, 2026, 03:02:40 PM
Author Topic: Spindle Speed Control  (Read 15741 times)
« on: March 22, 2009, 10:43:21 PM »
Hello All,
I am trying to get program speed control for a Chinese mill. The mill presently uses a potentiometer. I have a CNC4pc Speed control board and have it working on PWM. Here's my problem. I cannot find the right settings to give me good speed control. I can get it tuned from 500 to 2000 rpm and then from 2000-4000 is way off. If I get it tuned from 2000-4000 then the 500-2000 is way off. Also, I am not sure what function the "Increment" setting plays and I can't find anything in the manual that explains it. But, it does effect the speeds.
Can anyone help me with this? I am beginning to get frustrated after a week of "cut and try".
Thanks for your help in advance.
Bob Keyes
Kentucky
Re: Spindle Speed Control
« Reply #1 on: March 23, 2009, 12:00:59 AM »
Hello All,
Bob Keyes
Kentucky
Bob,
    It may be the nature of the beast.  The CNC4PC board will put out a linearly scaled voltage (voltage directly proportional to PWM duty cycle), while the motor controller may have a non-linear control voltage to RPM relationship.  Have you checked the voltage required to achieve specific speeds?  If it's not linear, then you're kinda stuck.
« Reply #2 on: March 23, 2009, 08:15:20 AM »
Ray,
Thanks for your response. I checked it and it is linear from 1000 up. It is also linear from 200 to 1000. Looks like I will have to pick a range.
Thanks again.
« Reply #3 on: March 23, 2009, 10:43:34 AM »
Bob,
    Or, do what I did - customize the post for your CAM software.  I wrote a post-processor to manage the spindle on mine.  The CAM program spits out G-code, with spindle RPM in the S words.  My post-processor parses the G-code, finds the S words, and figures out the best motor speed (I have a 2-speed motor) and pulleys to use to minimize the number of pulley changes, then adds code to prompt me to change pulleys/motor speeds when necessary, and changes the S words to the proper values to make the VFD run at the correct speed.  Doing that would allow you to have a linear command value in the S words in your CMA program, but generate non-linear S words in the actual G-code you run on the machine, so it works the way you want it to.  With a simple relationship like you seem to have, you could easily do the translation directly in the CAM post processor.
« Reply #4 on: March 23, 2009, 04:13:50 PM »
Gosh, I think that might be over my head right now. I still don't know what the "increment" does on the speed control panel?? When you increase or decrease it what does it change??
« Reply #5 on: March 23, 2009, 04:40:27 PM »
I think when you click on the up and down arrows, that DRO defines how much the S word changes.
