Hello Guest it is October 23, 2026, 08:52:09 AM
Author Topic: Using a Contour Design Shuffle as a pendant  (Read 48792 times)
drmosh
Re: Using a Contour Design Shuffle as a pendant
« Reply #20 on: October 26, 2006, 04:08:13 PM »
Hey folks,
I have a licensed oem copy of Mach3, and a Shuttle Pro v2 controller.  I'm trying to get it setup up but I have a few problems:
1) I do not have a plugins folder in the Mach3 root directory.  If I have to create it myself (which seems a little strange) what is the exact folder name?
2) There is no Plugin option under the Config menu in Mach3
3) There is something (at least on my computer) on the Mach3 FTP site that IE7 does not like about that Java control.  Is there any other place to get the dll?
mt
« Reply #21 on: October 26, 2006, 04:30:50 PM »
What revision of Mach are you using?
drmosh
« Reply #22 on: October 26, 2006, 04:35:25 PM »
it's 1.84.001
« Reply #23 on: October 26, 2006, 04:37:57 PM »
I am not 100% sure but I think the plugin was from about version 1.90.035 onwards. As I said I am not 100% sure so maybe Brian or Art will confirm.
drmosh
« Reply #24 on: October 26, 2006, 05:19:58 PM »
Upgrading to r2.0 gave me the PlugIns directory and the option in the Config menu - 2 problems solved!
Now - do I install the DLL or the M3P file?  If it's the DLL, is there an alternate location I can download?  As I said, I don't think IE7 likes that Java control on the FTP site.
mt
« Reply #25 on: October 26, 2006, 05:24:09 PM »
Sorry dont know as I dont have a shuttle, if you PM me with your email I will download the dll and send it to you.
drmosh
« Reply #26 on: October 26, 2006, 05:26:23 PM »
Check your inbox...
Thanks!
m
« Reply #27 on: October 26, 2006, 05:39:17 PM »
Sent a mail to you, cant find the dll. Do you have the address for it?
drmosh
« Reply #28 on: October 26, 2006, 05:42:24 PM »
No - based on the other posts I only knew that it was somewhere "on the FTP site"
mt
« Reply #29 on: October 26, 2006, 05:52:55 PM »
I found it, should be in your mail.
