Hello
Guest
it is
November 13, 2026, 05:01:20 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach SDK plugin questions and answers.
Finished Plugins for Download
Map ALL standard Input and Outputs to a New Diagnostic screen!!
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Map ALL standard Input and Outputs to a New Diagnostic screen!! (Read 82533 times)
Ross
1
Re: Map ALL standard Input and Outputs to a New Diagnostic screen!!
Reply #10 on:
November 07, 2012, 08:31:33 AM »
I am using a highly modified Mach3 screenset but would like to replace the Diagnostics screen with your improved screen. Is there a way to cut and paste between screensets in Screen4?
Thanks for your help,
Ross
jestah
49
Reply #11 on:
January 15, 2013, 03:49:07 PM »
Scott,
I love your pluging and screen! It has made setting up my first ATC very easy. Could not have done it with out this screen as I could not find much info about mapping oem triggers and other items not already on the standard 1024 screen.
I would like to try making my own screen set so I have spent a few days poking about yours but I think I will give up and admit its well over my head. Could you give me a few clues as to how you went about mapping the io without a brain or macro? Also why do you use this method than a brain or a macro?
Many thanks!
poppabear
2,235
Briceville, TN, USA
Reply #12 on:
May 25, 2013, 09:08:00 PM »
Jestah,
Thanks, glad you like it!! How it was done was from within the plugin, thus no brains or VB.
Scott
Denford Miracle
26
Reply #13 on:
December 10, 2015, 04:50:04 PM »
Why didn't anyone answer Ross's question? I would like to do the same thing he wants to do. can you copy and past that page into a different screen set with .lset extension?
OR.... can I use the user defined: 1301 and modifiy my current LED? will the 1301 work?
I guess I can try and see what happens. lmao
Print
Pages:
1
2
Go Up
« previous
next »
