Hello Guest it is November 11, 2026, 11:14:42 PM
Author Topic: Mach3 will not load Please help  (Read 9131 times)
« on: March 14, 2009, 12:44:22 PM »
When I click on the mach3 icon the loading picture comes up but then hangs and does nothing.  Mach3 process is running but no application.  I have installed and uninstalled many times, turned off all startup items and non microsoft services. Driver test works and says I have ecellent system but still nothing happens past the loader picture.
I have a dell desktop 1.6Ghz 512 mb ram and 32mb graphics I have also turned off auto updates etc as in XP optermiser.  Please help!
PS also tried install of download on laptop and it ran fine past the loader screen so I assume the download is good
« Last Edit: March 15, 2009, 10:59:38 AM by owencnc »
Alax_11
Re: Mach3 will not load Please help
« Reply #1 on: March 16, 2009, 12:01:55 AM »
Install Microsoft framework, SpecialDriver and then try again.
« Reply #2 on: March 16, 2009, 03:55:47 PM »
if only I was more patient >:( >:( >:(
got so mad I started re-install of xp and wiped the lot then wife says (5% INTO FORMAT) did you see the reply you got on that mack thing!!  Hymmm, its mach but still.  I hope a clean install will make it a dedicated system anyhoo.  May I still encounter the same problem??
