Hello Guest it is October 16, 2026, 12:24:57 AM
Author Topic: Mach3 condition abnormal light  (Read 35632 times)
Re: Mach3 condition abnormal light
« Reply #10 on: March 15, 2009, 09:40:22 AM »
Jack, your xml file will be in the Mach 3 folder. Once you find it you will have to open it and edit it. As Chip has said, I normally don't encourage this but that is the only option to turn it off once it has been activated.
« Reply #11 on: March 15, 2009, 09:46:44 AM »
Jack, editing the xml may not be exactly straight forward. If you want to post your xml I'll edit it for you.
« Reply #12 on: March 15, 2009, 10:21:49 AM »
You could always use Screen 4 to remove it. :)
Easier than editing the .xml
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #13 on: March 15, 2009, 11:21:23 AM »
Hi, Jack
If your running a standard Mach3 install you'll find it located in C:\Mach3 folder, It's "Mach3Mill.xml", Make a Copy of it and Rename the copy to JackMach3Mill.xml and try it on your other computer.
If you'll respond to the PM message I'll help you get this sorted Out.
Chip
« Reply #14 on: March 15, 2009, 11:37:24 AM »
Sorry, no such folder or file visible to me.  Closest thing is xmlbackups???
Jack
Offline Chip
  •  2,055 2,055
« Reply #15 on: March 15, 2009, 11:50:18 AM »
Hi, Jack
Do a search for Mach3Mill.xml, If you have a standard install that should be it.
It's a File.
Chip
« Last Edit: March 15, 2009, 11:55:15 AM by Chip »
« Reply #16 on: March 15, 2009, 12:49:50 PM »
I found the file and there is a lot of stuff under normals.
Jack
Offline Chip
  •  2,055 2,055
« Reply #17 on: March 15, 2009, 01:28:54 PM »
Hi, Jack
You just need to delete the entire folder "normals" and save the xml file. Then your back to "Not" having the Normal/Abnormal Activated.
Chip
« Last Edit: March 15, 2009, 01:58:37 PM by Chip »
« Reply #18 on: March 15, 2009, 01:32:13 PM »
Will this affect anything else?
Offline Chip
  •  2,055 2,055
« Reply #19 on: March 15, 2009, 02:29:24 PM »
Hi, Jack
It will put you back to "Not" having "Normal/Abnormal" Activated, It Should Not change anything else.
I'll post a screen.set with the button Removed, then you won't have to deal with it ether way as "Gerry" stated.
Hind-Site being 20/20, Should have done that Anyway.
Edit: See below.
Chip
« Last Edit: March 15, 2009, 02:44:32 PM by Chip »
