Hello
Guest
it is
November 19, 2026, 08:55:27 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Pause & Resume Buttons
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Pause & Resume Buttons (Read 18831 times)
TunerTom
60
on:
March 09, 2009, 03:53:11 PM »
I have wired 2 push-buttons to Input Pins #12 & #13 respectively and have configured then as "Input1" and "Input2", "Active Low"
Is there a way to tie these switches to System Function "Stop File" (to pause) and "Run" (to resume operation)?
Thanks...
Logged
poppabear
2,235
Briceville, TN, USA
Re: Pause & Resume Buttons
Reply #1 on:
March 09, 2009, 04:14:52 PM »
Yes
Use a Brain it is very easy to do.
on the first rung
Input1->NoOp->Button(Pause)
on the second rung
Input2->NoOp->Button(Start)
I enclosed a brian for you called: tomsBrain
scott
Last Edit: March 09, 2009, 04:17:37 PM by poppabear
Logged
Carnoustie, Scotland
Reply #2 on:
March 09, 2009, 05:06:25 PM »
You could also just set them up as OEM Triggers rather than Inputs, then go to Config menu then System Hotkeys, you can then enter the OEM numbers for the functions you want. 1000 is Start, 1001 is FeedHold
Logged
TunerTom
60
Reply #3 on:
March 10, 2009, 03:48:03 PM »
Hey guys, I took a look at the Brain forum and that led me to a video explaining how to use Brain Files. I think that feature is simply awesome! I set up the Brain file that pappabear sent me and it works perfectly!
Thanks, both of you for your help
TunerTom
Logged
poppabear
2,235
Briceville, TN, USA
Reply #4 on:
March 10, 2009, 04:26:04 PM »
Logged
Reply #5 on:
March 10, 2009, 05:44:52 PM »
Yes Brains are a nice feature, I use a few in Mach but wish they could do a few other things, then again Scotts MAD Plugin adds some of the features I would have wanted in the Brains
Logged
Print
Pages:
1
Go Up
« previous
next »
