Hello Guest it is October 15, 2026, 10:32:14 PM
Author Topic: HELP!!!! Please abnormal condition Mach3 - Rhinocam2 PROBLEM  (Read 33628 times)
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: HELP!!!! Please abnormal condition Mach3 - Rhinocam2 PROBLEM
« Reply #10 on: March 12, 2009, 05:06:58 AM »
What is the message in the abnormal list telling you.
Your last code blocks look fine. The only thing I would remove is the G40.1
Double click the abnormal button and select yes, this will make that condition normal, then try your code again.
Graham
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #11 on: March 12, 2009, 05:38:46 AM »
Hi, Jack
Well, It looks like we both have Corrupted XML files, Spoke with "Graham", He's another Moderator hear, "G-code-Guru" He suggested to create and Try a New XML After testing it a bit himself, Dam, The only thing I didn't Try, It was working a little funny hear, But not as bad as it was for you.
Let us know, Chip
« Reply #12 on: March 12, 2009, 06:39:13 AM »
What is XML?   How do I try anew XML?
Jack
« Reply #13 on: March 12, 2009, 08:06:40 AM »
Basically what they are saying is set up a new profile by entering the settings for ports and pins etc manually.
« Reply #14 on: March 12, 2009, 12:04:05 PM »
Mecsoft (Rhinocam) called me and set up an on line meeting with both of us in control of my computer.  Truly a very painless way to deal with a problem!!!   The tech showed me the problem witht he post, explained it and solved the problem with the post.
Mecsoft has proved their great support and great attitude.   One really finds out how good a software company is when dealing with problems!
Jack
