Hello Guest it is October 21, 2026, 06:21:47 PM
Author Topic: setting "cut depth" by number  (Read 9827 times)
Offline cor
  •  23 23
« on: March 02, 2009, 02:38:46 PM »
Hello out there,
I am playing arround a bit with lazycam and I cannot set a "cut depth"
I have made a simple straigh horizontal line in dxf, loaded it in lazycam.
When I select the "layers" button. I have "rapid height", "cut start", "cut depth" , by default "cut depth" is 0.
When I enter for example -13 and press the "set all layers" , it does it. But when I post the g-code it is still set at the default setting.
When I select the "set depth" (on the right) button I can set the depth with my mouse and this is than also set in the "cut depth" line, when posted it works fine and the z-ax goes down as ordered.
But why can I not select the "cut depth"in the window and than press the "set all layers" button ??
Hope someone understands this explanation and can tell me what i am doing wrong  :(
thanks,
Cor
Offline cor
  •  23 23
Re: setting "cut depth" by number
« Reply #1 on: March 03, 2009, 01:14:15 PM »
What the hell!!!!!!
Just made a whole new post to explain my problem more clearly with screenshots etc...... With this "last" try it suddely worked...... must be gremlins at work here in my computer  >:(
I found out that i was doing something wrong, i didn't select all seperate lines before klicking the "set all layers" button.
Cor
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #2 on: March 03, 2009, 02:57:34 PM »
Hi, Cor
I always use Set to layer, Then Set to All layers, After loading a new File to work on.
With the file you've been using it has really only one Layer "Default" which has a bunch of Chain's in that layer.
If you want to cut part of the file at different depth's you need to move the Chain's to a new layer or a diff. layer.
Then the "set layer" and "set All layers" will make more sense.
Chip
« Last Edit: March 03, 2009, 02:59:29 PM by Chip »
Offline cor
  •  23 23
« Reply #3 on: March 03, 2009, 04:24:29 PM »
I am starting to understand all this now :-)
Cor
