Hello Guest it is November 13, 2026, 05:31:13 PM
Author Topic: Non persistance when doing config setup  (Read 25926 times)
Re: Non persistance when doing config setup
« Reply #10 on: July 28, 2006, 10:30:13 AM »
Brian I made the change, closed Mach and they stayed in place. Then I changed the motor pins to get it referencing in the correct direction and that screw my jog directions up. Is there a chance that the referencing code is reversed?
Mike
« Reply #11 on: July 28, 2006, 10:43:49 AM »
You can change the Home Negative  state under the config/ Homing and Limits
Hope that helps
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #12 on: July 28, 2006, 10:48:24 AM »
Thanks Brian......sometimes I get tunnel vision :-[
Mike
« Reply #13 on: July 31, 2006, 11:10:38 AM »
Hi Brian, Art and or anyone else who might know. ;D
I need to be able to manually override my persitant limit switches and can't. I finally found the check box on the settings page.....thinking all this time it was in the congif :-[, but I cannot get a green led. This is all I need to be able to go ahead with the test. I may not actually since I not over the strep throat yet, but am getting there.
Mike
