Hello Guest it is October 21, 2026, 04:45:47 PM
Author Topic: unable to post more as ca 10 chains  (Read 27108 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: unable to post more as ca 10 chains
« Reply #10 on: March 03, 2009, 05:10:41 PM »
Hi, Cor
Well I removed my Mach3 Lic. also now and get the same results that you get.
Guess you will need the Mach3 Lic. at least.
Edit: I think this is mostly correct below.
Mach3, "Demo Mode" & LazyCam, "Demo Mode", LazyCam, Will only post 50 lines of G-code.
Mach3, "Licensed Version", LazyCam, Will post 500 lines of G-code, But will not post Offset's, Pocketing and Such.....
Mach3, "Licensed Version", LazyCam, "Licensed Version", Will post Offset's, Pocketing and Such.....
Chip
« Last Edit: March 03, 2009, 07:36:37 PM by Chip »
Offline cor
  •  23 23
« Reply #11 on: March 04, 2009, 09:37:16 AM »
Hey Chip,
Thanks for the info and help, this would explain all :-)
These lines are just to check my cnc router wat the accuracy is, if all is ok , i will get those licences.
Again, thanks for helping me out,
Cor
