Hello
Guest
it is
October 21, 2026, 07:52:34 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
CUT QUALITY REALLY RUFF
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: CUT QUALITY REALLY RUFF (Read 31295 times)
EMPIRE_CUSTOMS
11
Re: CUT QUALITY REALLY RUFF
Reply #10 on:
March 03, 2009, 11:24:58 AM »
ok i was using the 5x5c-plasma-c .... but i swithched on friday to the 1390 it seems to alot better... but the veins are still there not as bad though
Carnoustie, Scotland
Reply #11 on:
March 03, 2009, 02:28:45 PM »
Dont see anything amiss from your xml at first glance
Could it be looseness in your machine?
Have you tried slowing the accel a bit to see if its any better?
EMPIRE_CUSTOMS
11
Reply #12 on:
March 03, 2009, 04:41:09 PM »
yeah i droped the speed down from 140 ipm to 110 ipm on some 3/16" running 80 amp consumbles at 90 amps (per ez-router) .. i have even tried it a lil faster with the same results .. i am worried it might be the cpu beacuse this problem didn't start untill i got sheetcam to talk to mach3 .. when i was writing code using lazy cam mill it ran fine .. just took forever to write the code after drawing the part.....
i just dont know what to do know. out of ideals
EMPIRE_CUSTOMS
11
Reply #13 on:
March 03, 2009, 04:43:13 PM »
and i have loosen the bolts to the trannys and re tightened them back up like i was told from ez-router.. thanks for all the help so far guys
Overloaded
4,923
Reply #14 on:
March 03, 2009, 06:14:31 PM »
Hello Mark,
All was well with LazyCam ?
Problem started when you switched to SheetCam ?
Maybe it is a post processor setting in SheetCam.
Run a simple dxf through both cams and see if there is a difference in the cuts.
Just a thought,
RC
EMPIRE_CUSTOMS
11
Reply #15 on:
March 04, 2009, 02:48:39 PM »
tried that the cut quality was the same if i do it in lazy cam or sheet cam .. but today i had a tech come in and look at the machine to make sure that nothing was wrong with the plasma cutter .. we tried something we slowd it to 39 ipm and it looked great i will post a pic here in a min .. but know the circles arent't so pretty i am doing a lead in and lead out using arc any othe ideals i treid using no lead in and just a lead out .. and vice versa
EMPIRE_CUSTOMS
11
Reply #16 on:
March 04, 2009, 03:26:01 PM »
Print
Pages:
1
2
Go Up
« previous
next »
