Hello Guest it is October 15, 2026, 07:47:45 PM
Author Topic: Mach3 and THC, more problems  (Read 41048 times)
Re: Mach3 and THC, more problems
« Reply #10 on: February 26, 2009, 05:23:50 PM »
Please take a screenshot of the diagnostics screen as soon as you start Mach (Dont press reset or anything else).
Offline mrpeja
  •  114 114
    • Embroidery Machines
« Reply #11 on: February 27, 2009, 01:50:13 AM »
Hood,
there are three screenshots, before reset, after reset and before reset with thc on pressed. Names are self explanatory.
Could I have problems with licence? (no licence or bad or wrong licence file)
mrpeja
« Reply #12 on: February 27, 2009, 05:57:55 AM »
You seem to have enable 1, 2 and 3 all set to Port1 pin 8, is that right? Dont see a need for that and it may cause issues.
What hardware do you have exactly, ie do you have breakout boards and can you post a link to the THC unit.
Offline mrpeja
  •  114 114
« Reply #13 on: February 27, 2009, 06:59:25 AM »
Hi Hood,
Enable 1,2 and 3 are for X, Yand Z axis. In my hardware are all connected together.
I builded my own THC device.
Now something iterresting:
I just downloaded Mach3 R3.042.020 version, installed it and see in Hel PAPA FABIO licenced!!!!!!!
What is this?
What in means "lockdown"?
I didn't purchase any licence, i intend to do this next few days.
Maybe this is the reason why I have problems?
Witch version do I need to install?
mrpeja
« Reply #14 on: February 27, 2009, 08:20:25 AM »
When do you see "Hel PAPA FABIO licenced!!!!!!!"
Is it when you go to Hekp menu then Sbout Msch3................
Or is it just when you start Mach?
Offline mrpeja
  •  114 114
« Reply #15 on: February 27, 2009, 09:26:02 AM »
Hood,
I mistake by typing.
When I go to Help and then "About Mach3" I see PAPA FABIO
Belows is animation in green color, various names are listed, etc
I tried both Mach3 R3.042.020 and Mach3 R3.042.021 versions, Papa Fabio is in both Help/About...
And both acts like I described before
mrpeja
« Reply #16 on: February 27, 2009, 12:52:39 PM »
If you have Enable 1, 2 and 3 all going to the same pin then I dont see a need for you to have them all set up.
Did you buy this machine from someone secondhand?
« Reply #17 on: February 27, 2009, 04:57:25 PM »
I have also THC300 but I have also some problem ,with THC ON/OFF when I push the button from Mach3 screen it will work but if I use on off button by the
G-code using M3 will work most of the time but M5 never work so I have to stop mach3 and then I stop the plasma by push button from mach3 scream .
and also I don't see much diffrent by the THC-300 it locks to me it is not working.because  some time the torch come down until touch the matrial.
please I need help withe THC-300
Saleh
