Hello Guest it is September 09, 2026, 01:31:30 AM
Author Topic: Button to call a menu item ?  (Read 35029 times)
Offline Greolt
  •  956 956
« on: February 19, 2009, 03:05:58 PM »
I know I have seen info on this somewhere but despite my search efforts I can't find it.  :)
Just want an on-screen button to call the video window plugin, menu item.
Sure I can do this with a button script.     This is with Scream4.
Thanks,  Greg
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Button to call a menu item ?
« Reply #1 on: February 19, 2009, 04:21:20 PM »
Currently you can't acess Plugin control using
Code: [Select]
DoMenu( 6,1 )
You might make a request to Brian to change this.
« Last Edit: February 19, 2009, 04:25:14 PM by zealous »
Offline Greolt
  •  956 956
« Reply #2 on: February 19, 2009, 04:53:52 PM »
Thanks for that Jason
Brian seems to be snowed under at the moment.
Might leave it for another time.  :)
Greg
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #3 on: February 19, 2009, 05:07:07 PM »
I don't know if there is any other call to the Video window that can be made, but maybe we can ask Scott(Poppa bear) to make a plugin to open them up ;) I will talk to him.
Offline Greolt
  •  956 956
« Reply #4 on: February 19, 2009, 05:11:19 PM »
Yeah if any one can do that it will be Scott.   :)
Posted a general question on it on the Yahoo group also.
Greg
« Reply #5 on: February 19, 2009, 05:17:15 PM »
Whoa...........  I will look if I can get a handle on it, BUT, you would have to make a plugin to then give you the ability to "Open" if from a button. With an LED like I do in MAD, or a Notify Plugins.
It would be far, far, easier for Brian to fix the "DoMenu" glitch..............
I will see if I can get a handle on it, and if I can, see if there is a way to launch it, but again it will have to be from a plugin that is the only way I know to even touch the menu bar.
scott
Offline Greolt
  •  956 956
« Reply #6 on: February 19, 2009, 05:45:36 PM »
OK as usual I don't realise the complexity of what I am asking for.   ;D
Not worth that sort of effort Scott.  Would have been nice but not a deal breaker.
Greg
Offline Greolt
  •  956 956
« Reply #7 on: February 20, 2009, 03:16:47 PM »
Sometimes the answer is close to home.
Local CNCer had the answer.
This code used as a button script,
sendKeys "%(P)V"
Calls the video window.  Works a treat.  :)
Thanks Rod.
Greg
EDIT:  No that one caused problems with Mach somehow.
This one seems to work,  SendKeys "+%(P)V"
Again thanks to Rod.
« Last Edit: February 21, 2009, 04:33:20 AM by Greolt »
« Reply #8 on: February 21, 2009, 08:44:55 AM »
Wow!!!
   Thank you for the pearl!! Learned somthing new!! Now I gotta look closer at SendKeys to see how it would work for other menu items..........
Scott
« Reply #9 on: February 21, 2009, 09:58:33 AM »
Did a little reading/testing.....
this also works
SendKeys("%PV")
Scott
