Hello Guest it is September 29, 2026, 11:58:45 PM
Author Topic: Putting Mach 3 to good use.  (Read 36734 times)
Re: Putting Mach 3 to good use.
« Reply #10 on: February 19, 2009, 03:48:57 PM »
N4NV,
 PUT your outside dim. on the pic , and I'LL make you a drwg , or dxf.
What version of cad you using?
Ed
Ed VanEss
« Reply #11 on: February 19, 2009, 04:12:23 PM »
Vince,
Scaling your pic to 36" long, it is 27" high.
Is this correct?
Ed
Ed VanEss
Offline N4NV
  •  398 398
« Reply #12 on: February 19, 2009, 05:04:50 PM »
36x27 would be a good size for the final layout.  I put my board in my scanner and scanned it, see attached.  I can scan it in any number of formats.  This one is in jpeg.  I believe that AutoCAD can import a file, but I have never been able to do it successfully.  I have autocad 2000.
Vince
« Last Edit: February 19, 2009, 05:10:26 PM by N4NV »
« Reply #13 on: February 19, 2009, 06:00:43 PM »
Yeah, what Ed said..Ron BB
« Reply #14 on: February 19, 2009, 06:38:02 PM »
Vince ,
drw is attached as 2004, I will save one as 2000, and repost it. hope it works for you.
All holes are .375.
Ed VanEss
« Reply #15 on: February 19, 2009, 06:41:09 PM »
here it is in 2000.
Let me know if this works for you.
Ed
Ed VanEss
Offline N4NV
  •  398 398
« Reply #16 on: February 20, 2009, 11:57:31 AM »
here it is in 2000.
Ed
Perfect!  Did you trace it from the jpg or were you able to somehow convert the jpg to AutoCAD?
Vince
« Reply #17 on: February 20, 2009, 12:38:24 PM »
Vince ,
You can open a jpg in autocad.  Go to insert/raster image. You can then scale it to size you want and trace your lines.
I traced the outside profile , then used offset for the inner lines. laid out all the cross lines ,
 then drew  one .375 hole. Then copy the hole and paste at all the intersections.
Your jpg. pic is on layer pic.
Glad to be a help
When it comes to electronics , I 'M  of no help, so I try to help where I can.
Ed
Ed VanEss
Offline N4NV
  •  398 398
« Reply #18 on: February 20, 2009, 01:57:13 PM »
I added the score numbers to the cross lines, the finish hole, starting holes, skunk marker and text.  I tried to delete the original jpg layer and AutoCAD would not let me.   Lazycam wants clean DXF.  If I do a save as and DXF will it get rid of any extraneous layers?
Vince
« Reply #19 on: February 20, 2009, 02:28:40 PM »
Vince,
Heres' the dwg with no pic. No , autocad won't let you delete layers that contain any thing.
You have to shut off the layer you don't want , then do a copy , open new dwg , and paste.
Ed
Ed VanEss
