Hello Guest it is October 23, 2026, 04:52:10 AM
Author Topic: MachTurn wizards  (Read 75051 times)
Re: MachTurn wizards
« Reply #10 on: September 27, 2009, 02:55:41 PM »
Ian,
When in Mach Turn just click the Wizard tab at the top of the screen and select the threading or the turning.
« Reply #11 on: June 21, 2010, 03:28:00 PM »
Where can I find some instruction on using the Turn wizard?
Half the time I put a value in, it sets it back to zero with no error message or explanation.
Do I need to be a Psychic to use them?
Ramsey
« Reply #12 on: June 21, 2010, 04:25:21 PM »
Ramsey,
There are no instructions.
So try it with simple / even numbers of input so you can check the posted g code.
I would recommend you set your config for radius and reversed arcs unchecked.
Make a few notes as you go along.....
« Reply #13 on: June 21, 2010, 04:44:51 PM »
also, you must hit the ENTER/RETURN key after each entry or it wont stick.
