Hello
Guest
it is
November 13, 2026, 12:14:11 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Feedrate Overide
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Feedrate Overide (Read 14005 times)
graver
22
Feedrate Overide
on:
February 14, 2009, 02:54:17 PM »
I am hoping someone can tell me what setting is causing me problems. I am running Mach on two machines. On one machine I cannot get the feedrate override to go up. It will go down just fine. I have looked at every setting in the configuration screens but can't seem to find the problem. I noticed the problem first on an older version and it seems to be persistent into the latest version. I'm sure it's something in my xml file but I can't locate it. Thanks for any help.
Andy
Logged
Carnoustie, Scotland
Re: Feedrate Overide
Reply #1 on:
February 14, 2009, 04:00:16 PM »
Are you using a SmoothStepper?
Could you please attach the problem xml, suggest you rename it graver.xml so that the forum will accept it.
Logged
graver
22
Reply #2 on:
February 14, 2009, 04:33:02 PM »
Yes I am using a smooth stepper. I don't have time right now to upload the file because I am on my way out the door. Does the smooth stepper plugin disable this function?
Thanks! Andy
Logged
Reply #3 on:
February 14, 2009, 05:06:15 PM »
OK that is your problem then, SmoothStepper will not allow greater than 100% FRO at this time, it is being worked on and hopefully soon the FRO will be handed back to Mach and that will allow greater than 100%
Logged
graver
22
Reply #4 on:
February 14, 2009, 09:40:12 PM »
Works for me!
Thanks for your help!
Logged
Print
Pages:
1
Go Up
« previous
next »
