Hello Guest it is November 19, 2026, 03:16:31 PM
Author Topic: MachTurn wizard problem  (Read 54956 times)
Offline N4NV
  •  398 398
Re: MachTurn wizard problem
« Reply #10 on: February 12, 2009, 07:37:31 AM »
The G53 puts it in machine co-ordinates so I can send the carriage to the tool change position without doing an M6.
I have tried LazyCam and LazyTurn 6 or 7 times and have never been able to get any code out of them.  I am pretty good at AutoCAD and can draw up a part in just a few minutes.  I would love to use that programs if I could ever get them to work.  See my most recent post to the LazyTurn forum.
Vince
« Reply #11 on: February 12, 2009, 08:36:57 AM »
Vince,
The programs work, it's just another learning curve. Go to members docs and look thru the LazyCam Turn
manual. It's not the best, but it should shorten the learning curve. I am not going to update it since
LazyTurn is going to replace lazycam turn. It's the only writtten info that you will find.
Offline N4NV
  •  398 398
« Reply #12 on: February 12, 2009, 10:25:06 AM »
Here is the DXF file for the Crosshead Guide that I spent 3 hours hand coding.  It took me literally 5 minutes to draw in AutoCAD.
Vince
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #13 on: February 12, 2009, 10:50:02 AM »
Just load up this file and see what you get, it works fine on my set-up R3.043.00
Graham
« Last Edit: February 12, 2009, 10:56:37 AM by Graham Waterworth »
Offline N4NV
  •  398 398
« Reply #14 on: February 12, 2009, 11:21:02 AM »
Below is what I got when I loaded your program into version 3.042.008.  I have not tried to load version 3.043 because I am a little gun shy from my last attempt to upgrade to the lockdown version .020 what killed my VB script.  What program/s did you use to produce the code?
Vince
  •  2,785 2,785
« Reply #15 on: February 12, 2009, 11:41:38 AM »
Ok, that is just a setting in Mach3 that is making it look like that. My setup is like this :-
Graham
Offline N4NV
  •  398 398
« Reply #16 on: February 12, 2009, 12:50:08 PM »
Graham, my setting are exactly the same as yours.  It must be version 3.043.  Well, I missed the reversed arcs in front.  Thanks for the post.
Vince
« Last Edit: February 12, 2009, 02:44:07 PM by N4NV »
« Reply #17 on: February 12, 2009, 02:07:03 PM »
Vince,
Check ...reversed arc's in front post.... in turn options tab.
Anytime you get those stupid crop circles that's what you need to do.
Offline N4NV
  •  398 398
« Reply #18 on: February 12, 2009, 02:43:02 PM »
Thanks Rich, that was it.  I'm glad I can keep my current version on my lathe.  It seems every time I change I get bugs that I have to figure out.  I installed V3.043 on my mill and now I get watchdog triggers several times a program.
Graham, I'm curious about the program to that generated the code.  The feed rate is .0039 which would take about 2 weeks to cut at that rate.  Looking over the code there is no tool I could use to cut it.   I was planning on using a 1/8" grooving tool.  I changed the DXF so code generated from it should work.  I extended the section at the front of the part by 1/8" so that the front side of the tool will end up making the proper rounded corner.
Vince
  •  2,785 2,785
« Reply #19 on: February 13, 2009, 02:20:11 AM »
Hi Vince,
what feed, speed, depth of cut & finishing allowance do you want and I will do you some code using your .125 tool, is it a ball end or a square end ?.
Graham
