Hello Guest it is November 19, 2026, 04:40:32 AM
Author Topic: Accessing value stored in a parameter  (Read 17052 times)
« on: July 22, 2006, 06:48:38 AM »
The manual has an example of using a probe to find the centre and diameter of a hole (section 10.7.12.3).
It stores the value for the calculated average diameter in paramater #1034
How to I know what the value is, after the program has run?
N320 #1034=[[#1014 + #1024] / 2.0] (find average hole diameter)
Re: Accessing value stored in a parameter
« Reply #1 on: July 22, 2006, 08:45:44 AM »
I think you can do a GetVar(1034) in VB...
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: July 22, 2006, 09:37:22 AM »
I was suggested to send the value to the message bar, if possible, how would this be done?
« Last Edit: July 22, 2006, 09:43:44 AM by looker1 »
« Reply #3 on: July 22, 2006, 09:47:45 AM »
You could do a macro like this:
Test = GetVar(1034)
Code("Msg, The Dia = " & Test)
OR you coudl do this
 Test = GetVar(1034)
MsgBox("Msg, The Dia = " & Test)
www.machsupport.com
