Hello
Guest
it is
October 22, 2026, 06:38:08 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
LazyCam (Beta)
japanese font can't be used
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: japanese font can't be used (Read 14510 times)
k.kuramochi
8
on:
February 02, 2009, 02:32:13 PM »
I'd like to use Japanese font on LazyCam.
I can see Japanese font name on font window when I select "TEXT" tab.
But Japanese charactor can't be dragged.
Could you tell me how to do.
Logged
budman68
2,352
Re: japanese font can't be used
Reply #1 on:
February 02, 2009, 02:35:53 PM »
Possibly you could use the font in your CAD program and save as a 11/12 ASCII dxf and import that into LazyCam?
Logged
Dave->
k.kuramochi
8
Reply #2 on:
February 04, 2009, 04:33:21 PM »
What is a 11/12 ASCII dxf? Is ther any difference between a 11/12 ASCII dxf and just dxf?
I tried to import dxf file which I made by visio. But I couldn't see any charactors on LazyCam.
Logged
budman68
2,352
Reply #3 on:
February 04, 2009, 04:53:59 PM »
It's just a type of dxf that seems to be the best for LazyCam.
As for just a "regular" dxf, I'm sure it's a certain type that you're using, it just doesn't specify which type.
Logged
Dave->
Chip
2,055
Gainesville Florida USA
Reply #4 on:
February 04, 2009, 08:43:15 PM »
Hi, k.kuramochi
Post your dxf file so we can look at it.
Do you have the Ignore "Text Entities" box un-checked in Setup, Loading Options in LazyCam.
Chip
Logged
Chip
2,055
Reply #5 on:
February 05, 2009, 03:40:55 AM »
Hi, k.kuramochi
Got your dxf, Several issues, The file name isn't recognized, I renamed it ttest.dxf, It's standard dxf AC1014 format but your Japanese Font is not recognized by LazyCam, Only 2 of my cad programs would even see it as Font's, See below.
There is a Autodesk/Autocad utility that may convert the format for you.
http://teknigroup.com/support/ACAD/kanji2007.html
Direct to the 2 files you may need:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8109007&linkID=9240618
Hope this Helps, Chip
Last Edit: February 05, 2009, 03:47:31 AM by Chip
Logged
Chip
2,055
Reply #6 on:
February 05, 2009, 03:07:27 PM »
Hi, k.kuramochi
Hears the original dxf, Whin I uploaded it the font letters changed to numbers.
Chip
Last Edit: February 05, 2009, 03:12:24 PM by Chip
Logged
Print
Pages:
1
Go Up
« previous
next »
