Hello Guest it is October 21, 2026, 04:05:54 AM
Author Topic: COPYCAT - "KOOL"  (Read 163960 times)
Re: COPYCAT - "KOOL"
« Reply #10 on: February 01, 2009, 02:32:27 PM »
For anyone following this thread. Here is  an improved video camera.  Can jog around and locate with in say  +-0.002 with an inch of clearance to the piece. Should you decide to change camera settings while in the wizard, or do something you "may" loose the camera and jogging but seems like a reset takes care of it.
« Reply #11 on: February 02, 2009, 06:31:41 PM »
Ron,
What does reset do or not do in CopyCat?
« Reply #12 on: February 02, 2009, 06:49:53 PM »
The lower left corner has the standard mach e-stop or reset button. Its a plain button, probably should have made it the common red image button, then it would be more obvious.
« Reply #13 on: February 02, 2009, 08:03:50 PM »
Ron, Sent you a PM
Rich
« Reply #14 on: February 02, 2009, 08:14:40 PM »
I was wrong! the reset button was supposed to be the standard reset, actually it is 'reset feed override'. I simply selected the wrong entry on the list in screen4. Il get a fix out for that.
« Reply #15 on: February 06, 2009, 10:58:41 PM »
Hi Ron,
I got a manual of sort put together for CopyCat. It would have been further along except got hung up on
creating a circle. If an arc was done then  couldn't do a circle / if a circle was done then only circles could be done and no arcs. The circle box will not light up. Hmm..... maybe you can shed some light.  I have some comments
and will post them for your thoughts.
Attached is the manual for night time reading.
The manual and future updates will be put into the members docs as a new topic.
« Reply #16 on: February 07, 2009, 05:28:26 AM »
I will have a look tomorrow. Ive been on the road, I will get home later today.
thanks for the effort on the manual, Im sure it will be helpful
Offline N4NV
  •  398 398
« Reply #17 on: February 07, 2009, 10:54:22 AM »
Rich, thanks for the manual, I was just using Copycat last week.  I too was using a video camera and could locate items within +-.002".
Vince
« Reply #18 on: February 07, 2009, 04:50:19 PM »
Vince,
Did you try using the full circle?
« Reply #19 on: February 07, 2009, 07:21:12 PM »
Very good Rich and Thanks! I have said it before and will say it again I'm sure. Great group of guys here and this just proves it. Some don't relise what an effort some put into helping others. I do.
Thanks Rich,
