Hello Guest it is October 25, 2026, 03:24:38 AM
Author Topic: Tool change macro  (Read 28276 times)
Offline N4NV
  •  398 398
Re: Tool change macro
« Reply #10 on: February 01, 2009, 04:52:28 PM »
The brain to for the PLC looks like this:
Current tool -->No Operation pass signal-->MOD:0-P:16
As soon as the current tool number changes, that is sent to the PLC via modbus.  As long as the current tool has not changed, the PLC does nothing.
Actually, the brain is constantly sending the current tool number to the PLC, but if the tool number sent is the same as the current tool on the turret the PLC does nothing.
Vince
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #11 on: February 01, 2009, 07:20:29 PM »
I think the best is to set a USERLED to tell the Brain it is time to rotate.
In your Brain have it look for LED2000
If LED2000 is true and tool# is not equal to current tool then get tool.
Anyways here is the complete code for something like that in your Macro:
Code: [Select]
'////MOVE THE MACHINE FOR TOOLCHANGE////
Code ("G53 G00 Z-0.200")'Move Z to position
While IsMoving() ' Wait for machine to stop
SLEEP(250)'Slow down cycle time for CPU resources
Wend
'MsgBox "Machine finished moving"
'//GET SET TOOL////
tool = GetSelectedTool() 'Gettool
SetCurrentTool( tool )'Set tool
Call SetUserLED(2000,1)'Activate Brain
'///Time wait for INPUT1
i=0'Reset timmer
Do 'Run timmer
SLEEP(500)'timmer 1/2 second intervals
 i= i+1'increment
If (IsActive(INPUT1)) Or GetOEMLED(800) Then'INPUT is active
  Exit Do  'exit function Continue
ELSEIf i>8 Then'if we have reached 4 seconds
'///Message box////
msg = "Please reseat tool and continue?"   ' Define message
title = "Tool Changer"   ' Define title
buttons = 1
response = MsgBox(msg,buttons, title)'Display message box
'///Responce was YES
If response = 1 Then' User chose Yes.
   'OK has been pressed continue
Else'///Responce was NO
     DoOEMButton(1021)'Estop system
End If'exit message
End If 'INPUT ACTIVE
Loop
Offline N4NV
  •  398 398
« Reply #12 on: February 01, 2009, 07:23:24 PM »
Thanks, I will give a brain for that a try.
Vince
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #13 on: February 01, 2009, 07:31:30 PM »
Great  ;D
You shouldnt have any problem setting the LED in the Brain.
Its too bad Hoods SetModOutput will not work because you could just do it all from the macro without a brain  ;)
