Hello Guest it is November 22, 2026, 05:20:49 PM
Author Topic: Mach3 No movement from X Y Z  (Read 15103 times)
« on: January 30, 2009, 07:43:56 PM »
Hello I'm new to cnc building. I need a lot of help lol. I have set up a controll board and three drivers for the stepper motors and all looks to be wired fine but when I goto test run with the motors hooked up but not installed for the mach3 mill nothing is happening. When I run them under mach3 plasma the X and Y work fine but not the Z any help so I can run under mach3 mill. Thx.
Offline Glenn
  •  129 129
Re: Mach3 No movement from X Y Z
« Reply #1 on: January 30, 2009, 07:54:18 PM »
  Hi ebc12451,  in mach mill,    under config, - ports and pins,- motor tuning -- enable x,y,z
   see if that helps
  good luck, Glenn :)
Don't assume anything.....it'll make a Manager out of U and Me!
« Reply #2 on: January 30, 2009, 08:05:52 PM »
Thx for the quick reply and yes under ports and pin / motor outputs are enabled and the step and drive pins are set to 2 and 3  4 and 5  6 and 7 the ports are set at 1
« Reply #3 on: January 30, 2009, 08:14:23 PM »
Glen thanks for the help but I just found out by trial and error that the dirlow active and the step low active had to be enabled it now seems to be working.
Offline Glenn
  •  129 129
« Reply #4 on: January 31, 2009, 03:57:57 PM »
ebc12451,
  Good ol' trial and error to the rescue! Glad you are up and running!
    Glenn
