Hello Guest it is October 25, 2026, 01:35:07 AM
Author Topic: Assigning on-screen buttons to external push buttons  (Read 12297 times)
« on: January 30, 2009, 02:49:39 PM »
I was wonder how to assign a external push button to a function as on-screen button.
For example: I have 4 push buttons, connected to pins 2,3,4,5 ot LPT2.
How to assign them functions like:
1) Program Run (ALT-R)
2) Stop (ALT-S)
3) Hold (Spc)
4) Goto Zero
Thanks!
Re: Assigning on-screen buttons to external push buttons
« Reply #1 on: January 30, 2009, 02:58:49 PM »
Go to ports and pins and set up OEM Triggers with the pins you have the buttons attached to, then go to Config menu then System Hotkeys and enter the OEM code of the Mach button you wish to use with each trigger.
OEM for  Programme Run is 1000
OEM for Stop is 1003
OEM for Hold is   1001
OEM for GoToZ is 1017
« Reply #2 on: January 31, 2009, 07:41:11 AM »
Thanks a lot!
I did as you said, so now it works fine for me!
