Hello
Guest
it is
September 30, 2026, 01:42:59 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
VB and the development of wizards
Changing Homing-Speed with VB
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Changing Homing-Speed with VB (Read 44349 times)
CNC-Steuerung
52
on:
July 21, 2006, 09:14:41 AM »
I want to change the Homing-Speed inside of a VB-Script, but cant find the
Variable for this?
Has anybody done this before or an information about this?
Thanks for a short hint...
Greetings Wolfram
Brian Barker
3,860
Re: Changing Homing-Speed with VB
Reply #1 on:
July 22, 2006, 08:53:00 AM »
I think I am going to have a bit of time to play with that... I will see what I can find
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
CNC-Steuerung
52
Reply #2 on:
July 22, 2006, 09:07:09 AM »
Hi Brian,
"a bit of time???" - With a new born child?
Congratulations and all the best wishes!
Thanks and Greetrings,
Wolfram
Brian Barker
3,860
Reply #3 on:
July 22, 2006, 09:31:13 AM »
Wlofram,
I have found where to add access in the source code
I will see if I can get it to work for you by the end of the day ...
www.machsupport.com
Brian Barker
3,860
Reply #4 on:
July 22, 2006, 09:48:58 AM »
Well I think I have a test version that you can use
would you like me to Email it to you ?
www.machsupport.com
CNC-Steuerung
52
Reply #5 on:
July 22, 2006, 10:02:01 AM »
Hi Brian,
thanks a lot, yes, you can send it to my Email-Adress please.
Greetings,
Wolfram
Brian Barker
3,860
Reply #6 on:
July 22, 2006, 10:45:36 AM »
It is in the mail
www.machsupport.com
LarryMiranda
Reply #7 on:
August 04, 2006, 11:15:25 AM »
Please allow me to make a suggestion. Instead of e-mail, whu not post it here so that we can learn how to help ourself.
IE: "Give a man a fish and you feed him for today, teach a man to fish and you feed him for the rest of his life."
Larry Miranda
Brian Barker
3,860
Reply #8 on:
August 04, 2006, 02:26:17 PM »
I had to mail him a test build of Mach3.exe that I made... It is now in the release of Mach3
This is how you use it:
GetParam(YRefPer)
and SetParam(YRefPer,*********)
You would set the % of jog speed with the *********, this value could be from 1 - 100
Hope that helps
Brian
www.machsupport.com
Cuemaker
53
Reply #9 on:
August 07, 2006, 02:45:44 PM »
Can I get some help...
I have a program called minc94 that runs G-code. It runs under dos... I want to switch over to mach3.. I have a 3 axis mill and need help setting the configuration.
Print
Pages:
1
2
3
Go Up
« previous
next »
