Hello Guest it is October 28, 2026, 09:22:27 AM
Author Topic: simple brain HELP (;-)  (Read 9421 times)
vmax549
« on: January 28, 2009, 05:44:37 PM »
HIYA fellas ,  Need some help with a BRAIN. WHat I want to do is set 4 vars(99,98,97,96) to the value of the XYZA dros. SO far All I can do is lock up mach. I guess it takes brains to make brains and I don't have any.
Basically"
V99=Xdro
V98=Ydro
V97=Zdro
V96=Zdro
ANY ideas on how to make it work?
(;-)TP
Re: simple brain HELP (;-)
« Reply #1 on: January 28, 2009, 10:10:00 PM »
XDRO->NoOp->Var99
that doesnt work?
vmax549
« Reply #2 on: January 29, 2009, 06:46:28 PM »
Scot when I tried that mach locked up and the CPU when to 100% load and stayed there,  a few minutes later mach crashed all the way out to windows.
It looked like a timer was need somehow to limit the brain from running  wide open consuming all the cpu useage. Something like update the var once per .001sec or so.
I may have found another way around it so please don't waste any time on it.
Thanks (;-) TP
