Hello Guest it is November 07, 2026, 02:07:17 AM
Author Topic: Modifiying top file bar  (Read 14921 times)
« on: January 28, 2009, 12:55:39 PM »
I apologize if this has been covered. Is it possible to remove the top file bar so that only the control screen is visible and put the top bar in a limited location for access? I don't want my operators to have access to any system functions.
  Richard Konnen
Re: Modifiying top file bar
« Reply #1 on: January 28, 2009, 01:41:39 PM »
I believe this was discussed over at the Yahoo forum so do a search over there for it.
I'd be guessing it was about 3-5 months ago,
http://groups.yahoo.com/group/mach1mach2cnc/
« Reply #2 on: January 28, 2009, 04:49:38 PM »
there are OEM button codes that diable the top bar, and another to re enable it, look in the wiki.
Also, you can use a resource editor to remove stuff from the bar (Tormach does this), but, each time you install or reinstall you will have to go and redo the resource editor.
Or there is a Plug in..........
scott
« Reply #3 on: January 29, 2009, 05:59:44 AM »
Scott,
 Thanks, I hadn't read all the way to the end of the OEM list. Just what I was looking for. Also found a resource editor and was able to play with some settings also.
 Thanks again,
  Richard Konnen
« Reply #4 on: January 29, 2009, 01:51:18 PM »
Now I have another question. I found the OEM buttons to turn the top bar off. Is there a way to have the bar off at boot up?
  Richard
« Reply #5 on: January 29, 2009, 04:43:19 PM »
There's a check box in general config.
« Reply #6 on: January 29, 2009, 06:46:30 PM »
Gerry,
  Perfect, thanks. I have been using this program for 2 years and have yet to play with all the functions.
  again,
  Richard
