Hello Guest it is November 14, 2026, 01:49:26 AM
Author Topic: ModIO and serial plugin  (Read 13343 times)
« on: January 25, 2009, 05:14:21 PM »
Does the modIO board work with serial plugin enabled checked
Adam
Re: ModIO and serial plugin
« Reply #1 on: January 26, 2009, 02:25:40 AM »
Yes you can use it with the plugin support enabled. You can write brains to process the information to/from the plugin. There is also a ModIO plugin that can also be used.
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
email: peter at homanndesigns.com
