Hello Guest it is November 19, 2026, 04:33:25 PM
Author Topic: FileIn ?  (Read 13973 times)
FileIn ?
« on: January 25, 2009, 03:12:37 PM »
What's the correct usage of FileIn ?
I'd like to use this instead of calling a subprogram if that's possible?
thanks,
Rab
www.cnc-toolkit.com
vmax549
Re: FileIn ?
« Reply #1 on: January 25, 2009, 04:35:19 PM »
Hiya Rab, Are you working in VB or Gcode?
Re: FileIn ?
« Reply #2 on: January 26, 2009, 04:10:18 AM »
This is in gcode.
I'm sure that I had this working a few years ago but can't remember the formating,
I'm currently using P1 to call subprograms (O1....M99) but these are getting very long.
Rab
vmax549
Re: FileIn ?
« Reply #3 on: January 26, 2009, 09:32:06 AM »
There is no FILEIN command that I am aware of in MACH Gcode. (;-) Just the old SUB routine M98P1 ---o1,M99.
Hope that helps,(;-) TP
Re: FileIn ?
« Reply #4 on: January 26, 2009, 10:36:12 AM »
It may have been a vb command but called from within a gcode file ?
Rab
Re: FileIn ?
« Reply #5 on: January 26, 2009, 05:33:07 PM »
Where can I download the latest Mach / VB documentation ?
thanks,
Rab
vmax549
Re: FileIn ?
« Reply #6 on: January 26, 2009, 06:02:30 PM »
THe mach manual is on the Documentaion page and the VB script manual is in the Mach WIKI. There is a link to the manual there.
I don't see mention of the command FILEIN in either. BUT I do recall the filein from another controller language , I think AHHA. I have seen it before somewhere other than in MACH.
