Hello Guest it is November 13, 2026, 09:22:01 AM
Author Topic: Button not working with script  (Read 13419 times)
Offline Katoh
  •  287 287
« on: January 20, 2009, 04:50:46 AM »
Good evening to all.
I have a little dilemma I just cant resolve.
Using screen4 I altered the original (programme run screen) buy adding One button on the bottom called Tool Zero.
Buy using the VB script editor I wrote a script that has a small macro that allows for tool zeroing. through the editor the macro works well. I have saved it under macros as file M301 No probs there. In the MDI screen I can manually type M301 in the input and the macro runs no hassles.
My trouble is here I cant assign the Macro to the button I put in to the screen. I only get a Script er Compile Error.
Ive read through other posts to no avail.
Any Thoughts
Katoh
Katoh
Offline Greolt
  •  956 956
Re: Button not working with script
« Reply #1 on: January 20, 2009, 05:02:48 AM »
Did you use the following as the button script?
Code "M301"
Offline Katoh
  •  287 287
« Reply #2 on: January 20, 2009, 05:31:48 AM »
Thats all it was.
Katoh
Offline Greolt
  •  956 956
« Reply #3 on: January 20, 2009, 06:59:03 AM »
You're welcome.   :)
