Hello Guest it is November 01, 2026, 10:53:17 AM
Author Topic: What are "splines" & How do I get rid of Them?  (Read 18283 times)
« on: July 19, 2006, 11:00:19 PM »
Okay total newbee question, I created a simple vector drawing in Adobe Illustrator and exported it to .DXF.  When I import it into Lazy Cam it says I can't import "Splines." What do I do now?
Re: What are "splines" & How do I get rid of Them?
« Reply #1 on: July 22, 2006, 08:46:28 AM »
look to see if there is a way to break the splines into lines...
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: July 22, 2006, 01:39:02 PM »
Thanks for your reply Brian.  The biggest problem here is that I don't know what "Splines" are (in this context) so I don't know how to "break them up into lines." The drawing is a simple outline with some compound curves ( an electric guitar pickguard) but nothing special. It seems to me that it shouldn’t be so hard to get this to convert. . . I’m surly doing something wrong.
« Reply #3 on: July 22, 2006, 03:07:54 PM »
The compound curves are splines :(
www.machsupport.com
« Reply #4 on: July 22, 2006, 03:19:19 PM »
Bummer, does that mean that Lazy cam can only deal with polygons and simple curves?  If so, what can I do, short of laying out $8500.00 for artcam to cut out these parts?
« Reply #5 on: July 22, 2006, 03:23:12 PM »
We have the code to make the splines into lines but have not had the time to put it in :( I will talk to Art about adding it when he gets back next week.
Brian
www.machsupport.com
« Reply #6 on: July 22, 2006, 03:26:54 PM »
Thanks!!!
« Reply #7 on: July 22, 2006, 05:41:27 PM »
If you can, try saving as a v12 or earlier .dxf
If you can't, download this converter and try converting to a v10 .dxf
It *should* convert the splines to polylines.
http://www.a9tech.com/products/a9converter/
« Reply #8 on: July 23, 2006, 02:02:38 AM »
I tried your solution and it worked great!  I actually cut a real part this evening! Still I'm far from production but things are progressing.  Thanks!
